Since my local track is opening up in a month I decided to try to get some dyno tuning in. Unfortunately I was pressed for time and left without getting it fully dialed. I had an older TwEECer rev that needed an update so I only got 6 passes in. The first pull registered a 484rwhp/502ft.lbs (11.5 A/F). I richened up the maf curve and ended up with 544rwhp/537ft. lbs. Looks like this motor is happy with an A/F's at 10. The graphs also look like I've got some blower belt slip issues from 5100 rpm up. I was surprised that my old 42lb lucas injectors were able to support this horsepower level as well. They reached a peak duty cycle of 68%. Regardless I just purchased 80lb sieman dekas to replace them. Hopefully this setup will get me into the 10s!
Here's a video of one of the pulls:
