Vacuum System
DaRey8126
It seems a previous owner of my 91 GT Vert felt emissions controls were unnecessary. I plan to post a picture of the engine compartment, but I have the engine pulled now.
I am looking for diagrams, pictures, or suggestions of a list the emissions components (charcoal canister, lines, EGR lines, vacuum lines under the passenger fender well, etc) and their installed location.
I want to restore the system to what is correct rather than plugging lines with bolts.
In this post, the first picture is a sphere I found behind the passenger front fender. There appears to be a vacuum line in the area also. Don't know if they connect or where the sphere mounts.
The second image shows a bolt in the end of a vacuum line. The previous owner installed a 70mm Edelbrock throttle body. Not sure where this line is supposed to connect.
I'm not the most experienced here but I'm having some issues with my vacuum system too and saw this thread so I'll try to help.
I don't know what that sphere is, my car does not have one. I believe there's supposed to be a charcoal canister in that area which again my car does not have but usually they are rectangular in shape.
The other two vacuum lines appear to be for the EGR and Fuel Pressure Regulator. I'm guessing like my car, the previous owner removed the EGR system so they plugged that one with a bolt.
Good luck!
This may help.
After reviewing this, I don't think my car has that little vacuum line block with the red/green/black hoses. Where does it normally reside?
The come out from the fight side inner fender
