The true cost of 1990 Mustang coupe build
Bullogna
So my thought lately as I have read other peoples car adds on Facebook. As I watch other people destroy the other individuals cars exclaiming that the value is to high .I thought Why not post my adventure and what I have invested into my ..
My story starts July of 2018 I purchased a rough but drivable 1990 Coupe .The purchase price was $5400. The coupe came with some extra parts NOS to be exact quarter windows and Headlights...I sold off window Headlights interior wheels you name it every small piece I made $4200 selling parts off the car.Now the car still ran and drove and I am into the car for $1200 dollars
Now the money $$$ dump
INTERIOR
Map pocket delete $40 New
Black seat interior $379 New
Front re webbed seat belts $160 New
Seat belt plastic $49 New
Steering wheel $149 New
Momo wheel adapter $90 New
Tilt steering column $50 used
Black dash complete $200 used
Black center console $75 used
Black center armrest $55 used
Black door panels assy $200 used
Plastic shifter bezel $17 New
Center console cup holder $135 New
Shifter boot $50 New
Hurst shifter $61 New
Headliner $45
Scuff plates$35 New
Scuff plate screws $7
kick panels $70 install kit $12 New
Steering column cover $35 New
Ignition switch key $20 New
Center armrest latch plate $18 New
Floormats loop bound $65 gg bailey New
Interior door handle cups $20 New
Pwr window door lock plates $40.55 New
Pwr window and lock switches $25
Sunvisors black $45 Used
Speakers
Center armrest cover $45
5.0 rubber brake clutch pedal covers $24 New
Door lock actuators $35 New
Drivers door power harness $27 Used
Hurst short throw shifter plate $70
Door arm pads $55 New
Headlight switch $26 New
Hazzard switch $40 New
Turnsignal switch $20 New
Carpet $220
Led turn signal relay $5
Stock radio face plate $10 NOS
Sylvania radio long life display light bulb $5
$3059.55
The drivetrain is a stock 302 with 35,000 miles .The stock T5 leaks
Cash $$$ dump
Drivetrain
DRIVETRAIN
ats calipers $85 not added
Cobra calipers not installed
13inch front rotors powerstop $40 New
11.65 inch rear rotors powestop $66 New
3.73 gears $275
Rear end outer bearings and seals $50 New
Stainless front brake lines $60 New
Stainless rear brake lines side $65 New
Stainless center brake line $59 New
Rear brake hard lines $73 New
Yukon 28 spline axles $200 New
Axle studs $25 New
Billet rear caliper bracket $125 New
1993 42 mm taurus calipers $80 New
LMR conversion E brake cables $110 New
Sn95 spindles $200
E brake handle bracket 1R3Z-2A753-BA $20 New
Stop tech rear pads $50 New
GT master cylinder mc390186 $44 New
Cobra brake booster 54-73155 $88 New
MM master cylinder brake line kit $35 New
MM proportioning valve eliminator MMBAk 6 $20 New
Steering rack 712581 AGR marked as terminator $251 New
MM steering rack bushings $40 New
MM clutch quadrant $43 New
MM torque arm $480 New
MM subframe connectors add $170
Torque box enforcement brackets.add $40
Clutch adjustment knob $25 New
Diff cover proform 69501 $77.52 New
Rear Granatelli lower control arms $200 New
Front AJE lower control arms $325
MM lowering springs $200
MM panhard bar $395 New
KYB struts $225 New
KYB shocks 743020 agx $155 New
KYB quadshocks $33.59 New
Bumpsteer qa1 $90 New
MM caster camber plates $210 New
MM strut tower brace $180 New
Eibach front sway bar $252 New
Eibach rear sway bar $120 New
Sway bar end links Energy suspension$28 New
Energy suspension Poly front sway bar $18 New
Prothane Poly motor mounts $65
Unisteer steering shaft $175 New
MM K member front brace
Stifflers trans brace $150
Poly trans mount $40
Speedo cable $17 New
Speedo gear $16 New
Speedo speed sensor $30 New
Wilwood proportioning valve $50 New
Brake hub centric rings $20 New
18 inch Wheels $500 New
Tires $ 300 New
Jegs aluminum driveshaft $265 New
Rear spring poly bushings $25 New
Front spring poly bushings $25 New
Black security lug nuts $40 New
6.5mm wheel spacers $20 New
Aje k member
$7066.11
Cash $$$ dump engine and transmission
Engine
F1ZZ 6V012 BRM long block 2007
BBK Cold air intake $200
BBK Headers $300
70mm mass air $200
Accufab 70mm throttle body $270
24 injectors $75
Flowmaster h pipe
Flowmaster exhaust
Starter powermaster 9162 $62
Power steering line 3/2018
R134A ac conversion 1/2010
Smog pump deleted
Idle.adjustment plate $55
Trickflow 11r 170 head $1650
Trickflow stage 1 cam $280
Trickflow pushrods $120
Trickflow intake $650
130 amp alternator $100 New
4ga wire black conversion $20
Alternator wire connector $6
Alternator bracket $36
130 A alternator optifuse 153150 $22
High flow water pump gmb 125 1560p $65 New
Comp CamTiming chain $35 New
Timining chain cover $23 New
Arp head bolts $40 New
Arp head bolts bushing reducer $20
Undrive pulleys $85
PRP timing pointer 8521 $47 New
Jegs water pump timing cover bolts $75 New
Rt351 motorcraft thermostat $13
Dayco PB1084SS Harmonic balancer$165 N
Scorpion 1.6 roller rocker$265 New
Intake gasket $28 New
ARP Intake bolts $28 New
ARP crankshaft bolt 1502501 $28 New
BBK fuel rails $100 New
Percy headers gasket $12 New
BBK 1617 fuel pressure gauge $70 New
Billet water neck $37
Trickflow valve covers $150
Egr delete cel plug sensor $35
Mishimoto radiator hoses $150
Mishimoto radiator $250
Mishimoto fans $175
Valve cover gaskets
Valve cover bolts $17 add
MSD Distributor
MSD 6AL $225
Fidanza 386501 lightened flywheel $200 New
Centerforce pressure plate cft361830 $200 new
Centerforce clutch $150 new
Centerforce n1714 throwout bearing $50 new
Centerforce 42001 pilot bearing $20 new
50048 clutch alignment tool $5
TKO Bellhousing $255 New
TKO 600 TCET5008 $2700 new
UPR EGR Delete $30 add
Pressure plate bolts dowel pins M6397A302 add $12
Flywheel bolts arp $22
Stage 8 header bolts add $12 new
Crankshaft woodruff key $6 new
Clutch cable
Ac compressor bracket $70 new
$11,688
Exterior
Smoked Taillights $135
Smoked Headlights $150 New
Cobra Grill $57 New
Door handles $20
Window channel $45
Door seals $33
Trunk seal $22
Driver side door hinge pins $20
Cowl hood $300 New
Driver side door hinge $20 used
Front bumper cover $100 used
Passenger rear quarter window $118 used
Drivers quarter window $245 used
Exterior mirrors $15 used
Headlight bolt kit $7 New
$1287
